Tags
> Related links
Visit our LabVIEW Wiki Hardware Portal
> Linear Actuator
Hansell
post Jul 22 2008, 05:09 PM
Post #1
I want a LabVIEW icon under my name!
Member
Using LabVIEW Since:2008
LV:8.5.1 ,. ,.
Canada Nothing Selected Nothing Selected
I've been looking for a while now, but I can't seem to find any rod type linear actuators with labview drivers made. I was wondering if anyone knows any distributors that provide actuators (with a stroke length of at least 30cm) with drivers made for labview.
Thanks
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
PaulG.
post Jul 22 2008, 07:09 PM
Post #2
Member
Using LabVIEW Since:1998
LV:8.5 ,8.20 ,7.1
United States Nothing Selected Nothing Selected
Actuators need a controller and an amplifier. LabVIEW communicates with the controller. I've used rotary actuators that had built-in controllers and amplifiers, but they were serial devices and a "driver" wasn't needed. I know a few of the bigger motion control companies (Aerotech, Parker) will sell you "Software Development Kits" laugh.gif for LabVIEW if you are going the separate controller/amplifier route.
"Whether they be the musician cats in my band or the real cats of the world, they all got style." -Ray Charles
Tags
+Quote Post
ned
post Jul 22 2008, 09:56 PM
Post #3
Member
Using LabVIEW Since:1999
LV:8.5 ,8.6 ,.
United States us_massachusetts Nothing Selected
QUOTE (Hansell @ Jul 22 2008, 01:09 PM) *
Try Copley Motion? I've been controlling their stepper motor amplifiers through LabVIEW (they provide a free ActiveX component and LabVIEW examples). They work well in my application and were simple to set up. I haven't used their linear actuators but I'm willing to guess that they're equally easy to use.
Tags
+Quote Post
Maca
post Jul 22 2008, 11:25 PM
Post #4
Active
Member
Using LabVIEW Since:2004
LV:7.1 ,8.2.1 ,8.5.1
Australia aus_queensland Nothing Selected
What sort of force and frequency response are you after?
All the actuators I work with at work, are fed an analogue signal that controls the shuttle in the servo, A PID loop is then used to control the displacement or load.
Can you give a bit more information on the application?
Tags
+Quote Post
martin@aerodynam...
post Jul 23 2008, 08:06 AM
Post #5
Premium Member
LV:8.20 ,8.0.1 ,7.1.1
Switzerland Switzerland Switzerland
QUOTE (Hansell @ Jul 22 2008, 07:09 PM) *
Thanks
http://www.maxonmotor.com/
Maxon has LabVIEW drivers for its drives RS232/CAN-bus
I used a maxon motor/drive with RS232 driver for a test bench - works great...
What is your application?
What do you need to do?
Happy Wiring! (User defined "Swiss Wire Class" for neutral data only!!!)
Tags
+Quote Post
vugie
post Jul 23 2008, 08:15 AM
Post #6
Active
Member
Using LabVIEW Since:2006
LV:8.2.1 ,. ,.
Poland Nothing Selected Nothing Selected
I used LinMot motor and controller. It had not LabVIEW drivers, but it was very easy to write such for RS232. Worked very good.
Tags
+Quote Post
Collapse
> Similar Topics
    Topic Title Replies Topic Starter Views Last Action
No New Posts   1 Ducc 687 13th June 2005 - 05:06 AM
Last post by: Ducc
No New Posts   2 mezga 535 20th July 2006 - 11:23 AM
Last post by: mezga
No New Posts   4 chtan23 802 19th July 2006 - 06:36 PM
Last post by: ahlers01
No New Posts   7 torekp 743 28th November 2006 - 05:25 PM
Last post by: jimi
Time is now: 7th October 2008 - 12:33 AM
