Visit our LabVIEW Wiki External Code Portal.
Jul 1 2008, 09:28 PM
Post
#1
I've come back for more. Member Posts: 2 Joined: 24-June 08 Member No.: 11839 Using LabVIEW Since:2003 LV:8.5 ,8.2.1 ,8.20
Hello to all,
Is there a method to call a function as an input parameter to a function called from a dll? The reason why I am asking is due to the fact that I am trying to call the following function from a DLL. RtxConfigPollingMode(unsigned long PollingInterval, void (*RtxServiceDevices)(void)); this function calls the RtxServiceDevices function as an input parameter, how can I do this with LV? ThanksNAdvance Tags
| Ad |
Post
Tags
Jul 1 2008, 10:40 PM
Post
#2
![]() Very Active Member Posts: 126 Joined: 6-February 07 From: Houston - Texas Member No.: 7703 Using LabVIEW Since:2006 LV:8.20 ,8.0 ,.
RtxConfigPollingMode(unsigned long PollingInterval, void (*RtxServiceDevices)(void)); You can consider parameters as input terminals. So what wrong with connecting the output result of the RtxServiceDevices)(void) to the terminal of RtxConfigPollingMode() dll function? This post has been edited by Thang Nguyen: Jul 1 2008, 10:40 PM Tags
Jul 2 2008, 06:02 PM
Post
#3
Extremely Active Premium Member ![]() Posts: 976 Joined: 9-April 04 From: Rotterdam Member No.: 349 Using LabVIEW Since:1992 LV:8.5.1 ,8.2.1 ,7.1.1
You can consider parameters as input terminals. So what wrong with connecting the output result of the RtxServiceDevices)(void) to the terminal of RtxConfigPollingMode() dll function? I'm afraid you missed the point that this is a function declaration and the parameter in question is a function pointer. And the OP should be advised that this is not possible in LabVIEW (well it is sort of if you create a LabVIEW DLL that exports a function with the right protoype, then LoadLibrary and GetProcAdress that function and pass the resulting pointer as an uInt32 to the Call Library Node that calls this function). Sort of because there are many caveats to this approach not the least is the difficulty about maintaining the whole thing. Another one is that it will play very badly once the DLL is created and you upgrade to a new LabVIEW version since the LabVIEW DLL VI can only run in the same LabVIEW process if the caller is exactly the same version as the LabVIEW version used to create the DLL. So while it is possible the solution is a nightmare to maintain in the long run. Instead the OP will have to create a wrapper DLL in C that translates between this callback function and another LabVIEW callback mechanisme such as occurrences or user events. Good luck. Rolf Kalbermatter Tags
Jul 2 2008, 07:14 PM
Post
#4
I'm afraid you missed the point that this is a function declaration and the parameter in question is a function pointer. And the OP should be advised that this is not possible in LabVIEW. Thanks alot for your help. I see that the dll will have to be re-written to accomodate LabVIEW FD Tags
Jul 16 2008, 09:15 PM
Post
#5
![]() I want a LabVIEW icon under my name! Member Posts: 3 Joined: 12-December 06 From: Boulder Colorado Member No.: 7251 Using LabVIEW Since:1999 LV:8.5.1 ,8.20 ,.
I am trying to call the following function from a DLL. RtxConfigPollingMode(unsigned long PollingInterval, void (*RtxServiceDevices)(void)); this function calls the RtxServiceDevices function as an input parameter, how can I do this with LV? ThanksNAdvance Another approach that may work is if you know that, when called from the LabVIEW application you are developing, you will always use the same device servicing function, and furthermore that function is known at development time. It may be possible to write some C wrapper code such as: CODE //prototype of device servicing function you know you can use (must actually be defined somewhere!) void myTrustyDeviceServicer(void); //shallow wrapper that simply always uses above service routine myLVRtxConfigPollingMode(unsigned long PollingInterval) { RtxConfigPollingMode(PollingInterval, myTrustyDeviceServicer); } If there are a couple of alternative for which device service function you will need you can expand the above function with a case/switch statement. If the RtxServiceDevices function cannot be known until run time, then you are correct in your conclusion that a re-write of the DLL is in order. Still I am not sure this approach will work; it really depends a lot on what it is doing. Your task begins to wind away from LabVIEW and into the realm of C programming -Good Luck, Chip -------------------- Analysis and synthesis should be alternated as naturally as breathing in and breathing out. - Goethe
Tags
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
2 | naruto | 1517 | 21st July 2004 - 12:25 PM Last post by: naruto |
1 | Ruud | 1579 | 8th September 2004 - 02:33 PM Last post by: Jim Kring |
0 | whitesu | 1014 | 8th September 2004 - 03:24 PM Last post by: whitesu |
1 | jcbalding | 2031 | 17th September 2004 - 08:22 PM Last post by: Irene_he |
| Time is now: 7th October 2008 - 12:46 AM |
