Tags
> Related links
Visit our LabVIEW Wiki Hardware Portal
> USB in Labview 6
DrTrey
post Jun 30 2008, 08:41 PM
Post #1
One hit wonder!
Member
Using LabVIEW Since:1994
LV:6.0 ,. ,.
Nothing Selected Nothing Selected Nothing Selected
I am looking for someone who has made Labview 6i work with a USB device. I am building a USB device and I have Labview 6 on hand and hate to buy the upgrade. Can anyone help?
DrTrey
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
hooovahh
post Jul 2 2008, 06:24 PM
Post #2
V I Engineering, Inc.
Using LabVIEW Since:2004
LV:8.5 ,8.0.1 ,7.1.1
United States Nothing Selected Nothing Selected
Wow I don't think I can help but could you clarify a little please.
QUOTE
Do you mean, have LabVIEW interact with a USB device? What kind of USB device, USB camera, NI-USB DAQ device? USB thumb drive?
Do you mean running LabVIEW from the USB drive? Do you mean as a development system? Do you mean running a LabVIEW executable? Do I ask too many questions?
"When I look at the smiles on all the children's faces, I just know they're about to jab me with something."
"Oh, people can come up with statistics to prove anything, 14% of people know that."
"If you really want something in this life, you have to work for it - Now quiet, they're about to announce the lottery numbers!"
"Weaseling out of things is important to learn. It's what separates us from the animals ... except the weasel."
Tags
+Quote Post
rolfk
post Jul 14 2008, 05:53 PM
Post #3
Premium Member
Using LabVIEW Since:1992
LV:8.5.1 ,8.2.1 ,7.1.1
Netherlands Switzerland Nothing Selected
QUOTE (DrTrey @ Jun 30 2008, 04:41 PM) *
DrTrey
You give indeed to little information about the type of device and such. If it is some DAQ device or similar however the standard mode of operation is to write a device driver and the according user space DLL wrapper. That can be easily imported into LabVIEW through the call Library Node in a way that is completely independant of the LabVIEW version.
Other means would be to use libusb to control your device. Interfacing LabVIEW to libusb through the Call Library Node is about the same in terms of version dependance but the libusb API is not really meant to be interfaced by high level applications like LabVIEW or VB and you will run in some issues that are usually most easily solved by writing a wrapper DLL that translates between the low level API and the LabVIEW Call library Node.
Last but not least there is USB Raw device support in NI-VISA. Not sure though from which version of LabVIEW this VISA feature is properly supported. While the feature is completely implemented in VISA, LabVIEW needs to support some extra API access modes to use this feature. A quick look in LabVIEW 6.0 shows that the necessary Nodes to use USB through VISA are not present. LabVIEW 6.1 is the first to support this interface but you will need a recent version of VISA installed on your computer. The first VISA versions had lot's of difficulties supporting USB device RAW access.
Princiapially option 1 will require you to really write C code. The other two options won't but can't be really considered a lot easier. You will simply implement the bit level protocol of your USB device in LabVIEW itself. Option two will still require some serious C knowledge to be able to properly interface to libusb through the Call Library Node. From that perspective using VISA to control your USB device would be probably the simplest solution but don't expect it to be trivial. One disadvantage of the two last options will be that you can't really leverage off that solution for non-LabVIEW users such as Visual Basic, Visual C, etc.
Rolf Kalbermatter
Tags
+Quote Post
neB
post Jul 14 2008, 06:40 PM
Post #4
Certified Kool-Aid Kid
Premium Member
Using LabVIEW Since:1998
LV:7.1 ,. ,.
United States Germany Nothing Selected
QUOTE (rolfk @ Jul 14 2008, 01:53 PM) *
Rolf Kalbermatter
Excellent reply Rolf!
I had to reply because I justread this Nugget (on the Dark-Side) by Shane where he introduces us to using VISA to interact with USB devices. I would have remained silent if the timing was not what it was.
Ben
Tags
+Quote Post
Collapse
> Similar Topics
    Topic Title Replies Topic Starter Views Last Action
No New Posts   3 guy 6865 21st May 2003 - 09:59 PM
Last post by: Mark Hanning-Lee
No New Posts   5 JackHamilton 6483 12th August 2005 - 07:27 AM
Last post by: rolfk
No New Posts   1 seckley 4916 20th December 2002 - 04:36 AM
Last post by: Michael_Aivaliotis
No New Posts   0 Michael_Aivaliotis 4397 20th May 2003 - 09:10 PM
Time is now: 29th August 2008 - 06:46 PM
