Visit our LabVIEW Wiki Hardware Portal
Jun 28 2008, 12:19 PM
Post
#1
Active Member Posts: 16 Joined: 8-January 06 Member No.: 3829 LV:7.1.1
Hi All, I have PCI 6221 DAQ Card (68 pin) and using LabVIEW 8.0, I want to control the servo motor using this config., I have experience running the servo motor using PLC by inputting the calculated number of pulses to the servo run command in ladder logic for controlling the applicaton & it worked fine. Similarly I want to run the servo motor using LabVIEW so that I can input some pre defined pulses but dont know how to input the pulses, what pins to be connected and used. I have mitsubishi servo motor and its drive, could any body help me out with some sample code and hardware connection configuration. Thanks & RegardsJames
Tags
| Ad |
Post
Tags
Jun 30 2008, 05:06 AM
Post
#2
![]() Extremely Active Premium Member ![]() Posts: 577 Joined: 8-December 03 From: Dallas, Texas Member No.: 208 Using LabVIEW Since:2000 LV:8.20 ,7.1.1 ,.
My Gallery
Servo motor & pulses???
umm... call me crazy but I thought you controlled servo motors w/ voltage & current (speed & torque) It was the stepper motors that required the use of pulses -------------------- Norman J. Kirchner Jr.
Automation Software Engineer ~,~ The Captain Was Here Premium Blend ![]() Tags
Jun 30 2008, 06:05 AM
Post
#3
![]() Very Active Premium Member ![]() Posts: 178 Joined: 19-January 05 From: Switzerland Member No.: 1396 Using LabVIEW Since:1998 LV:8.20 ,8.0.1 ,7.1.1
Hi All, I have PCI 6221 DAQ Card (68 pin) and using LabVIEW 8.0, I want to control the servo motor using this config., I have experience running the servo motor using PLC by inputting the calculated number of pulses to the servo run command in ladder logic for controlling the applicaton & it worked fine. Similarly I want to run the servo motor using LabVIEW so that I can input some pre defined pulses but dont know how to input the pulses, what pins to be connected and used. I have mitsubishi servo motor and its drive, could any body help me out with some sample code and hardware connection configuration. Thanks & RegardsJames What interface are you using for your drive? Without knowing that, it's not possible to give you a good advice... I'm using analog output or RS232, for my drives but it depends on the drive... Servo motor & pulses??? umm... call me crazy but I thought you controlled servo motors w/ voltage & current (speed & torque) It was the stepper motors that required the use of pulses Yes and no... It depends on the drive, if you have an intelligent drive, you just say the drive to move 200 pulses (encoder pulses) and the acc. speed s-curve etc. and the drive does the rest for you... -------------------- ![]() Happy Wiring! (User defined "Swiss Wire Class" for neutral data only!!!) Tags
Jun 30 2008, 01:04 PM
Post
#4
My Gallery
Yes and no... It depends on the drive, if you have an intelligent drive, you just say the drive to move 200 pulses (encoder pulses) and the acc. speed s-curve etc. and the drive does the rest for you... Thanks for bringing me back to reality. I knew that. that's the danger of doing late night posting. -------------------- Norman J. Kirchner Jr.
Jul 1 2008, 01:59 PM
Post
#5
One hit wonder! Member Posts: 1 Joined: 7-April 07 Member No.: 8312 Using LabVIEW Since:2006 LV:8.20 ,. ,.
Greetings All!
Coming soon is a LabView compatible driver that will allow servos, steppers and even VFDs to be controlled over a digital network. This does NOT require a "smart servo or drive" but a digital network communication card in your PC and network enabled servos, stepper and vfds can easily be commanded by driver VIs. This data should be posted on the NI Tools site later this month and also at www.yaskawa.com. Note: Min. Requirements are PC running Vista or XP Pro; LabView 8.5 and Mechatrolink Network enabled drives; Motion profiles are point to point and velocity due to operating in the Windows environment. Benefits: No breakout boards with losts of wiring; Plug n Work USB stlye connectors. LabView is the brain of your Mechatronics application and the drives and motors are your Mechatronics muscle. Tags
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
2 | rubo | 1427 | 21st December 2004 - 02:06 PM Last post by: zeus224 |
3 | pallen | 1105 | 17th December 2004 - 11:27 AM Last post by: happl_scott |
0 | zeus224 | 690 | 20th December 2004 - 03:44 PM Last post by: zeus224 |
6 | zeus224 | 1361 | 12th January 2005 - 03:17 PM Last post by: James McAnanama |
| Time is now: 6th October 2008 - 11:12 PM |
