Please post topics into this forum that relate to specific features introduced in LabVIEW 8.x.x. The post will be moved to the appropriate forum if it does not meet this requirement. Your post may also be moved if it's deemed that it would fit better in another forum regardless. For example: LabVIEW OOP topics should go to the GOOP forum.
Jun 27 2008, 02:31 AM
Post
#1
I want a LabVIEW icon under my name! Member Posts: 3 Joined: 27-June 08 Member No.: 11864 Using LabVIEW Since:2008 LV:8.5.1 ,. ,.
I'm using labview 8.5 right now and I've some projects saved using 7.1. Is there any way I can open the file with 8.5 or do I have to redo everything ?
Tags
| Ad |
Post
Tags
Jun 27 2008, 02:47 AM
Post
#2
![]() Very Active Premium Member ![]() Posts: 160 Joined: 18-January 08 From: Montréal, Canada Member No.: 10515 Using LabVIEW Since:2000 LV:8.6 ,8.5 ,.
I'm using labview 8.5 right now and I've some projects saved using 7.1. Is there any way I can open the file with 8.5 or do I have to redo everything ? Post your code... How can we help otherwise? Tags
Jun 27 2008, 03:16 AM
Post
#3
![]() Very Active Member Posts: 76 Joined: 30-March 07 From: Brisbane Member No.: 8228 Using LabVIEW Since:2005 LV:8.5 ,8.0.1 ,7.1.1
I have projects written in LabVIEW 7.1 and can open them with no problems in LabVIEW 8.5 the only problems you might encounter is driver incompatibilities and if any of your code has the block diagram removed, there might be other upgrade issues too, the release notes would contain more information. The only VIs I've found that have been too old for LabVIEW 8.5 to open at all are LabVIEW version 5.1 or older.
-------------------- Test Engineer
Certified LabVIEW Architect(CLA) Tags
Jun 27 2008, 03:55 AM
Post
#4
Post your code... How can we help otherwise? I have projects written in LabVIEW 7.1 and can open them with no problems in LabVIEW 8.5 the only problems you might encounter is driver incompatibilities and if any of your code has the block diagram removed, there might be other upgrade issues too, the release notes would contain more information. The only VIs I've found that have been too old for LabVIEW 8.5 to open at all are LabVIEW version 5.1 or older. I cannot seem to view my Sub VIs for the port read and config. There is this question mark image on the block for the Sub VIs
Attached File(s)
Tags
Jun 27 2008, 12:06 PM
Post
#5
I cannot seem to view my Sub VIs for the port read and config. There is this question mark image on the block for the Sub VIs As Karrisap mentions, you've got some missing vis because you have not all DAQ drivers installed. I get the same problem you do at home because I don't have any DAQ installed on that computer. It's looking for zadvd.llb that should be installed in vi.lib folder. Install your drivers and you should have no problem loading your code.
Tags
Jun 30 2008, 01:22 AM
Post
#6
As Karrisap mentions, you've got some missing vis because you have not all DAQ drivers installed. I get the same problem you do at home because I don't have any DAQ installed on that computer. It's looking for zadvd.llb that should be installed in vi.lib folder. Install your drivers and you should have no problem loading your code. ![]() I see. Thank you very much. But how do I install the drivers ? You see I'm only in charge of the programs and the boss sends someone else to do the installation part. Tags
Jun 30 2008, 02:46 AM
Post
#7
You can download the latest drivers from NI website.
Tags
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
2 | donroth | 2227 | 13th June 2004 - 05:06 AM Last post by: Khalid Ansari |
0 | Laurie Garrick | 2643 | 18th June 2003 - 03:53 PM Last post by: Laurie Garrick |
1 | andy810915 | 2290 | 4th September 2003 - 04:30 AM Last post by: Michael_Aivaliotis |
0 | TomWP | 2327 | 10th February 2004 - 04:25 PM Last post by: TomWP |
| Time is now: 29th August 2008 - 06:19 PM |
