Check out our OOP Code Repository Files or visit the LabVIEW Wiki OOP Portal.
Jun 24 2008, 09:52 PM
Post
#1
![]() Extremely Active Member Posts: 357 Joined: 6-February 07 From: Homburg/Germany Member No.: 7689 Using LabVIEW Since:2004 LV:8.5 ,8.0.1 ,.
My Gallery
Hello LAVAs!
I want know if it's possible to flatten a LVOOP Class to a binary string from e.g. C++, so I can unflatten them in LabVIEW to a LVOOP Class ? Thanks, Eugen -------------------- Tags
| Ad |
Post
Tags
Jun 24 2008, 10:03 PM
Post
#2
Very Active Member Posts: 63 Joined: 1-June 06 Member No.: 5171 LV:8.0 ,. ,.
Hello LAVAs! I want know if it's possible to flatten a LVOOP Class to a binary string from e.g. C++, so I can unflatten them in LabVIEW to a LVOOP Class ? Thanks, Eugen The question's a little confusing. How are you using your LVOOP class in C++? Are you calling a LabVIEW-built DLL that creates and uses LVOOP classes? To flatten the LVOOP class appropriately, you will need to use the LabVIEW Flatten to String function. You can create a wrapper VI that calls this function with a class input and create an exported DLL function to call this from C++. Tags
Jun 24 2008, 10:08 PM
Post
#3
My Gallery
The question's a little confusing. How are you using your LVOOP class in C++? Are you calling a LabVIEW-built DLL that creates and uses LVOOP classes? To flatten the LVOOP class appropriately, you will need to use the LabVIEW Flatten to String function. You can create a wrapper VI that calls this function with a class input and create an exported DLL function to call this from C++. I think to create a structure (=cluster) in C++ with all elements what LVOOP Class Contol Cluster has, than cast them to binary string (or byte array) and send over TCP/IP. This post has been edited by Eugen Graf: Jun 24 2008, 10:13 PM
Attached image(s)
Jun 25 2008, 01:36 AM
Post
#4
![]() LV R&D Envoy NI ![]() Posts: 1188 Joined: 15-August 06 From: Austin, TX Member No.: 5877 Using LabVIEW Since:2000 LV:8.5.1 ,. ,.
My Gallery
I think to create a structure (=cluster) in C++ with all elements what LVOOP Class Contol Cluster has, than cast them to binary string (or byte array) and send over TCP/IP. You can create a flattened cluster string in C++ and then write a custom unflatten routine for your class that can parse the string and populate the fields of your class. But if you want to use the Unflatten From String primitive, then you'll have to format the data like a LabVIEW class gets flattened. What does an LVClass look like when we flatten it? The string has four parts: Just write code in C++ to generate this string and you can have LabVIEW unflatten it. Contrariwise, you can have LabVIEW flatten the string and you write the C++ function to parse it. IMPORTANT NOTE: The flattened form of LabVIEW data is portable to any endian platform. We always flatten int32s, uInt32s and other data types into big endian order. If you are on a little endian machine (any Mac, Windows or Linux box is little endian), make sure that your custom write/write functions take care of reversing the bytes. -------------------- "A VI outside a class is a gun without a safety. Data outside a class is a target."
--- A message from LabVOOP R&D Tags
Jun 25 2008, 06:50 AM
Post
#5
Changing the world, one VI at a time. Premium Member ![]() Posts: 1665 Joined: 22-October 02 From: San Francisco, CA Member No.: 17 Using LabVIEW Since:1995 LV:8.2.1 ,8.5 ,7.1.1
My Blog
My Gallery
What does an LVClass look like when we flatten it? The string has four parts: Great info. I've added it to the LVClass Data Storage Format wiki page. -------------------- Tags
Jun 27 2008, 10:31 AM
Post
#6
![]() Extwemely Active Premium Member ![]() Posts: 1594 Joined: 23-January 05 From: Here Member No.: 1431 Using LabVIEW Since:2003 LV:7.0 ,7.1 ,.
Great info.
Here, for example, is a flattened class object (I put the string into slash notation to make this "easier" to parse): CODE \00\00\00\02\12\10Bacteria.lvclass\00\00\00\05\00\06\00\07\00\b\00\01\00\00\00\00\00\t\00\00\00\00\00\00\00\f\00\00\00\04abcd\00\00\00\00 Next is the PStr that is the name of the class: Bacteria.lvclass. After that are 2 NULL pad bytes to get the length back to a multiple of four. Which of the two bytes is the PStr length, 0x12 or 0x10? Bacteria.lvclass is 16 (0x10) characters . If 0x12 is the length and 0x10 is the beginning of the string, then the string is 0x11 bytes long and needs three null characters for padding, not two. If 0x10 is the length, there shouldn't be need for padding. Or am I missing something? QUOTE Next is the first version number: 5.6.7.8. That's the version number for Bacteria.lvclass. Next is the second version number: 1.0.0.11. Are you sure you didn't switch the 8 and 11 here? In the code, \b comes in the first part and \t comes in the second. -------------------- More than meets the eye...
Tags
Jun 27 2008, 11:18 AM
Post
#7
My Gallery
Which of the two bytes is the PStr length, 0x12 or 0x10? Bacteria.lvclass is 16 (0x10) characters . If 0x12 is the length and 0x10 is the beginning of the string, then the string is 0x11 bytes long and needs three null characters for padding, not two. If 0x10 is the length, there shouldn't be need for padding. Or am I missing something? What you're missing is that I didn't fully explain how the PStr is encoded. a) The PStr is a length byte plus the text, so that is 17 bytes, not 16, and thus padding is required. b) The first byte, 0x12, is the total length including padding: 18 c) The second byte, 0x10, is the total length not including padding: 16 d) Thus 18 + the two length bytes = 20 QUOTE Are you sure you didn't switch the 8 and 11 here? In the code, \b comes in the first part and \t comes in the second. \t is the tab character, which I thought was character 11, but I checked my ascii table. Turns out it is 9. I corrected my original post. I also added the hex view for clarity. \b is not hex 11 as you thought. It's the slashcode for character 8.
Jun 27 2008, 11:33 AM
Post
#8
What you're missing is that I didn't fully explain how the PStr is encoded. a) The PStr is a length byte plus the text, so that is 17 bytes, not 16, and thus padding is required. b) The first byte, 0x12, is the total length including padding: 18 c) The second byte, 0x10, is the total length not including padding: 16 d) Thus 18 + the two length bytes = 20 Well, I still don't really understand - shouldn't the total length, including padding (step b), be 20? Or did you mean total length including the length bytes? What's the actual use case for having two length bytes? If you have just one length pad, you should easily be able to calculate the needed padding, shouldn't you? QUOTE \t is the tab character, which I thought was character 11, but I checked my ascii table. Turns out it is 9. I corrected my original post. I also added the hex view for clarity. \b is not hex 11 as you thought. It's the slashcode for character 8. I actually had a double mix-up here. I didn't check either and thought tab was ASCII 8 and backspace is ASCII 9 (when it's the other way around). That would explain why I thought that \b is ASCII 11. I also fixed the wiki article. -------------------- More than meets the eye...
Tags
Jun 27 2008, 01:38 PM
Post
#9
Very Active Member Posts: 157 Joined: 26-September 05 From: Zurich Member No.: 3076 Using LabVIEW Since:2006 LV:8.2.1 ,8.20 ,6.1
Well, I still don't really understand - shouldn't the total length, including padding (step b), be 20? Or did you mean total length including the length bytes? What's the actual use case for having two length bytes? If you have just one length pad, you should easily be able to calculate the needed padding, shouldn't you? Seeing as the descriptors can be very long and complicated, it's very useful sometimes to know how to easily skip to the next item in the descriptor. Hence the first value. Of course one could deduce the next offset based on the data available, but I'd rather take the 0.25 Bytes (on average) cost of the second length value for faster response time in LabVIEW. Isn't this all derived from the general and pretty much global method of defining type descriptors? Such type descriptors for Controls can get pretty involved. Shane. Ps I see your point regarding the value of 18 instead of 20. I think this might also be a result of a global method of handling type descriptors IIRC. I think the descriptor for a PStr lists the total length as the total length of the DATA and thus excludes the two bytes for the size information. It will thus always be 2 Bytes short of a multiple of 4. This post has been edited by shoneill: Jun 27 2008, 01:42 PM Tags
Jun 28 2008, 01:23 AM
Post
#10
My Gallery
What's the actual use case for having two length bytes? If you have just one length pad, you should easily be able to calculate the needed padding, shouldn't you? I have no idea. That's how PStrs are encoded whenever they're flattened in LabVIEW data.
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
14 | PJM_labview | 6186 | 2nd January 2007 - 07:08 PM Last post by: brian175 |
2 | PJM_labview | 2142 | 7th July 2008 - 08:50 PM Last post by: rolfk |
1 | m3nth | 1422 | 10th September 2005 - 04:22 AM Last post by: klessm1 |
1 | jlokanis | 939 | 27th September 2005 - 01:03 AM Last post by: mballa |
| Time is now: 6th October 2008 - 11:10 PM |
