Tags
> Forum Rules
Please post topics into this forum that relate to specific features introduced in LabVIEW 8.x.x. The post will be moved to the appropriate forum if it does not meet this requirement. Your post may also be moved if it's deemed that it would fit better in another forum regardless. For example: LabVIEW OOP topics should go to the GOOP forum.
> String Arrays into DIAdem pdf report, How to import string arrays into the "Signal" input of DIAdem
Mohammed.Achraf
post Jun 4 2008, 05:26 PM
Post #1
I've come back for more.
Member
Using LabVIEW Since:2007
LV:8.5 ,8.0 ,.
Egypt Nothing Selected Nothing Selected
Dear All,
Actually i'm trying to create a self generated pdf report using DIAdem Report vi after acquiring some data from an instrument we have in the lab
the data isn't a waveform graph , it's a strings contains the Frame Error rate percentage (e.g. 0.00% - Double) , Numbers of Frames Tested (Integer) , number of error frames (Integer) and finally a Pass/Fail result (string).
i wish i can make something looking like this table in the attached document file "channel1.doc"
the point is that i'm new in using this tool (DIAdem) , and as you see these tables are with different data formats. i'm thinking of converting all of these results as strings , but the "Signal" input of the DIAdem Report VI is in dynamic data type and is not accepting the string format.
i made a simple vi to demonstrate my problem , it will not generate the above table but it is the same concept.
Please someone help me in this and tell me how to generate the above tables.
this is urgent please
Thanks in Advance
Attached File(s)
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Ton
post Jun 4 2008, 06:25 PM
Post #2
CCT It
Premium Member
Using LabVIEW Since:2001
LV:8.5.1 ,6.1 ,8.2.1
Netherlands hol_utrecht Nothing Selected My Blog My Gallery
I advice you to use Data-portal properties.
In your TDR you can create a table that has several entries.
In LabVIEW you need to generate a VI that stores these entries inside the data-portal.
The help-file of DIADem is sometimes hard to study but the record macro function is very usefull.
Ton
Certified LabVIEW Developer
Shouldn't you be programming a Code Repository solution?
Tags
+Quote Post
Mohammed.Achraf
post Jun 10 2008, 12:15 PM
Post #3
Member
LV:8.5 ,8.0 ,.
QUOTE (tcplomp @ Jun 4 2008, 08:25 PM) *
Ton
actually i don't understand exactly what your talking about
i know how to create templates in TDR but dunno how to organize my data in it , plus still the input "Signal" of the DIAdem report VI i can't use as you see in the VI
Tags
+Quote Post
Collapse
> Similar Topics
    Topic Title Replies Topic Starter Views Last Action
No New Posts   1 splitsecond 1397 12th March 2006 - 09:23 PM
Last post by: mballa
No New Posts   2 Michael_Aivaliotis 1791 14th January 2004 - 07:06 AM
Last post by: Michael_Aivaliotis
No New Posts   4 Mike C 2892 19th April 2005 - 05:09 PM
Last post by: Mike C
No New Posts   6 adavid 1498 16th March 2004 - 03:16 PM
Last post by: adavid
Time is now: 10th October 2008 - 11:18 PM
