Tags
> Forum Rules
Please post topics into this forum that relate to specific features introduced in LabVIEW 8.x.x. The post will be moved to the appropriate forum if it does not meet this requirement. Your post may also be moved if it's deemed that it would fit better in another forum regardless. For example: LabVIEW OOP topics should go to the GOOP forum.
> Remote Debugging of executable
a100man
post May 16 2008, 08:12 PM
Post #1
One hit wonder!
Member
Using LabVIEW Since:2004
LV:8.5.1 ,7.1 ,.
United States Nothing Selected Nothing Selected
Hello,
I've finally upgraded to 8.5.1 (from 7.1) and was curious to try out the remote executable debugging feature, but I was dismayed by how my very simplistic trial VI crashed and burned. I haven't seen any similar posts around here, so I was curious whether people are not using this feature, or are having better luck. I've attached a vi and it's executable which cause problems repeatedly. I should mention this is on WINXP. The steps are:
1. launch executable
2. Launch remote debugger (either on same machine or remotely)
3. Access block diagram
4. create probes on the millisecond multiple and the numeric.
5. close and re-create the probes one at a time
6. within a very short period of doing this, the probes will start to read 0, and the front panel will not update. Closing the VI creates a system error.
Any ideas?
Attached File(s)
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Time is now: 7th October 2008 - 08:10 AM
