Please post topics into this forum that relate to specific features introduced in LabVIEW 8.x.x. The post will be moved to the appropriate forum if it does not meet this requirement. Your post may also be moved if it's deemed that it would fit better in another forum regardless. For example: LabVIEW OOP topics should go to the GOOP forum.
May 15 2008, 09:10 AM
Post
#1
5 more posts to go! Member Posts: 5 Joined: 9-May 08 Member No.: 11460 Using LabVIEW Since:2008 LV:8.20 ,. ,.
I have some doubts on the Labview as i'm new to labview. Is there anyone know that is there any difference between v8.2.0 and v8.2.1? If the VI was previously created on the v8.2.0, does it able to run at v8.2.1? Does Labview v8.2.0 able to run at Window Vista? Anyone know about this?? Wish to get the answer as soon as possible...Thank you very much!!! Tags
| Ad |
Post
Tags
May 15 2008, 09:39 AM
Post
#2
![]() CCT It Premium Member ![]() Posts: 1291 Joined: 13-June 05 From: Woerden, Netherlands Member No.: 2399 Using LabVIEW Since:2001 LV:8.5.1 ,6.1 ,8.2.1
My Blog
My Gallery
Hi, I have some doubts on the Labview as i'm new to labview. Is there anyone know that is there any difference between v8.2.0 and v8.2.1? If the VI was previously created on the v8.2.0, does it able to run at v8.2.1? Does Labview v8.2.0 able to run at Window Vista? Anyone know about this?? Wish to get the answer as soon as possible...Thank you very much!!! LabVIEW 8.2.1 is a bug-fix release for LabVIEW 8.2.0. VIs created with one version can run on the other (they are automatically recompiled). Executables from one version can run on a computer with a runtime version of the other if you don't use TDMS functions. I don't know think Vista is supported with 8.2.1 since it was released at the same time. Ton -------------------- Tags
May 15 2008, 10:52 AM
Post
#3
![]() Very Active Premium Member ![]() Posts: 163 Joined: 1-January 08 From: Perth Member No.: 10325 Using LabVIEW Since:2006 LV:8.5.1 ,8.6 ,.
The National Instruments Product Compatibility for Microsoft Windows Vista explicity states that 8.2.1 works with Vista.
I believes this means 8.2.0 does not, but I can not confirm first hand. -------------------- all day...
Tags
May 15 2008, 12:19 PM
Post
#4
Very Active NI ![]() Posts: 90 Joined: 12-December 05 From: Austin, TX Member No.: 3674 LV:8.0
The National Instruments Product Compatibility for Microsoft Windows Vista explicity states that 8.2.1 works with Vista. I believes this means 8.2.0 does not, but I can not confirm first hand. 8.2.1 was specifically tested on Vista so that's why it is listed as compatible. There isn't some magic bit that makes previous versions of LabVIEW not work. I want to say I've run 8.2 on Vista (I haven't tried 8.0), but the officially supported version is 8.2.1. Tags
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
3 | guy | 7687 | 21st May 2003 - 09:59 PM Last post by: Mark Hanning-Lee |
5 | JackHamilton | 7269 | 12th August 2005 - 07:27 AM Last post by: rolfk |
1 | seckley | 5457 | 20th December 2002 - 04:36 AM Last post by: Michael_Aivaliotis |
0 | Michael_Aivaliotis | 4887 | 20th May 2003 - 09:10 PM Last post by: Michael_Aivaliotis |
| Time is now: 13th October 2008 - 07:08 AM |
