Tags
> Forum Rules
Please post topics into this forum that relate to specific features introduced in LabVIEW 8.x.x. The post will be moved to the appropriate forum if it does not meet this requirement. Your post may also be moved if it's deemed that it would fit better in another forum regardless. For example: LabVIEW OOP topics should go to the GOOP forum.
> Project corruption, LV 8.5.1 lvproj files getting corrupted
Val Brown
post May 14 2008, 05:37 PM
Post #1
Member
Using LabVIEW Since:1998
LV:8.6 ,8.5.1 ,8.2.1
Canada United States Nothing Selected
I have my 8.5.1 lvproj files getting corrupted frequently. Now I am using XP under Fusion but I don't understand how that's impacting this directly. Normal shutdowns and such -- no system crashes -- but still at times (that I can't even predict) the lvproj file gets corrupted.
So two questions:
1. Anyone else seeing similar behavior and, if so, what seems to precipitate or ameliorate it?
2. Anyone know of any way to fix a corrupt 8.5.1 lvproj file?
The power of NeuroCARETM
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Tomi Maila
post May 14 2008, 06:23 PM
Post #2
Drawing Tool - LVOOP example application
Premium Member
Using LabVIEW Since:2004
LV:8.5.1 ,8.2.1 ,7.1.1
Finland Nothing Selected Nothing Selected My Blog
QUOTE (Val Brown @ May 14 2008, 08:37 PM) *
Val, what way do your lvproj files get corrupted? The project files are xml files and are rather easy to edit with a text or XML editor such as freely available Microsoft XML Notepad. One thing you can try to do is to remove the "items in memory" section from the lvproj file or if that doesn't help then all the dependencies.
ps Are you using LabVIEW Classes?
Tomi
Tomi Maila
Tags
+Quote Post
Val Brown
post May 14 2008, 09:29 PM
Post #3
Member
QUOTE (Tomi Maila @ May 14 2008, 11:23 AM) *
Tomi
Thanks for the reply. I can't say precisely in what way they're getting corrupted. All I know is that I go to open the project (either double-clicking on its icon or starting up LabVIEW and then using File/Open...) and I get back the message that the project file is corrupted. Yes, I'm aware that they are XML and I can certainly open them even in regular Notepad but I didn't want to do any particular editing as I wasn't at all clear what to change. I'll give a try to removing the items in memory section.
No, I'm not using LabVIEW Classes.
Tags
+Quote Post
Omar Mussa
post May 16 2008, 03:26 PM
Post #4
Premium Member
Using LabVIEW Since:1996
LV:8.20 ,. ,.
United States us_california Nothing Selected
QUOTE (Val Brown @ May 14 2008, 02:29 PM) *
I'm sure that it is too late for your current problem but you inspired me to finish writing this article! You may want to read it even if you're not using LabVIEW Classes.
got VIPM?
Tags
+Quote Post
Collapse
> Similar Topics
    Topic Title Replies Topic Starter Views Last Action
No New Posts   0 Laurie Garrick 2668 18th June 2003 - 03:53 PM
Last post by: Laurie Garrick
No New Posts   2 jlokanis 1587 8th October 2007 - 04:04 PM
Last post by: Christina Rogers
No New Posts   3 rpursley 1492 14th November 2006 - 01:40 PM
Last post by: jimi
No New Posts   0 Phia 1721 13th July 2004 - 09:24 PM
Last post by: Phia
Time is now: 7th September 2008 - 07:03 PM
