May 13 2008, 02:21 PM
Post
#1
![]() Very Active Premium Member ![]() Posts: 207 Joined: 30-July 05 From: Tampa Bay Member No.: 2655 Using LabVIEW Since:2001 LV:8.5 ,8.2.1 ,7.1
My Gallery
When is a VI a "driver" ?
Tags
| Ad |
Post
Tags
May 13 2008, 02:34 PM
Post
#2
Certified Kool-Aid Kid Premium Member ![]() Posts: 1133 Joined: 6-December 02 From: Pittsburgh PA USA Member No.: 29 Using LabVIEW Since:1998 LV:7.1 ,. ,.
There is probably a forma definition of a driver somewhere, that I 'll others find and link. Years ago I asked "what is the difference between a mainframe and a super-mini computer?" The response was "Anything that cost more than $1M is a mainframe." To me a driver is software entity that translates opeartional requests into hardware interactions that produce required results. An automobile driver takes request "turn left" slow down" and manipulates the hardware for that end. A disk driver accepts read request (read 100 bytes from block sector 500) into a "seek command" "header verify" "read 512 bytes" "transfer to client buffer". Ben Tags
May 13 2008, 03:38 PM
Post
#3
Extremely Active Member Posts: 253 Joined: 30-December 05 Member No.: 3786 Using LabVIEW Since:1998 LV:8.5 ,8.20 ,7.1
... It's an over-used term at best. And "elegant" drivers would be about as over-used as you can get. -------------------- "Whether they be the musician cats in my band or the real cats of the world, they all got style." -Ray Charles
Tags
May 13 2008, 05:36 PM
Post
#4
![]() Confucius say, Man with tight trousers is pressing his luck. Admin ![]() Posts: 2320 Joined: 13-October 02 From: Planet Earth Member No.: 2 Using LabVIEW Since:1994 LV:8.5 ,8.2.1 ,7.1.1
My Blog
My Gallery
One thing that ticks me off to no end is when you discuss a new application with a customer and they bring up the fact that NI has "drivers" on their website so this should automatically translate to: "The app can be finished in a day or two right?" People, a hand full of turd balls does not translate to a full blown user interface with real time graphing, reporting and data analysis application. Unless of course you're a mystical fairy who shoots pixie dust out of your a** when you fly.
-------------------- Tags
May 13 2008, 05:43 PM
Post
#5
![]() Very Active Member Posts: 56 Joined: 7-August 06 From: Lexington, KY Member No.: 5791 Using LabVIEW Since:1996 LV:8.5 ,7.1 ,8.20
People, a hand full of turd balls does not translate to a full blown user interface with real time graphing, reporting and data analysis application. Unless of course you're a mystical fairy who shoots pixie dust out of your a** when you fly. That quote's going up on my door right now! Perfect. -James Tags
May 13 2008, 05:54 PM
Post
#6
My Gallery
.....a hand full of turd balls... First time I ever LOL'd reading a LAVA post! Richard Tags
May 13 2008, 06:04 PM
Post
#7
Extremely Active Member Posts: 269 Joined: 15-September 05 Member No.: 3014 Using LabVIEW Since:1998 LV:7.1.1 ,8.0.1 ,8.20
Unless of course you're a mystical fairy who shoots pixie dust out of your a** when you fly. I'm going to go put that on my resume right now. Tags
May 13 2008, 06:12 PM
Post
#8
But seriously folks, to me a driver is a piece of code that allows me to use LabVIEW to interface relatively easily with a piece of hardware. A VI can indeed be called a "driver". Many companies sell LabVIEW SDK's with their equipment. They contain vi's that contain the dll's or the CIN's or whatever that allow you to communicate and control their hardware. That to me would be a "driver" VI. But more accurately I would call it an xyzdeviceInterface.vi. Not a driver. The actual dll or C code is the "driver". Or am I full of pixie dust? -------------------- "Whether they be the musician cats in my band or the real cats of the world, they all got style." -Ray Charles
Tags
May 13 2008, 06:56 PM
Post
#9
![]() Extremely Active Member Posts: 285 Joined: 6-March 06 Member No.: 4344 Using LabVIEW Since:1997 LV:7.1.1 ,. ,.
The actual dll or C code is the "driver". Or am I full of pixie dust? I agree with that. If a VI is calling a device-specific DLL, I wouldn't call that VI a driver; the DLL would be the driver. I'd probably call a VI a driver if it was performing the hardware interface using only native Labview and OS functions (i.e. memory peeks/pokes). Gary Tags
May 13 2008, 07:39 PM
Post
#10
My Gallery
I agree with the points that Gary and Paul have brought up. To take it a step further, a driver (to me) is something that a piece of hardware *can't* work without (think printer driver), whereas if you've written a LabVIEW VI that controls a device, the device may still stand on its own with something written in (god forbid) C or VB or Cobol or Fortran or Pascal or JAVA or HPV.... ... ...
Thanks for the input, I've been trying to get people to stop calling LabVIEW VI's "drivers" because I think that terminology can confuse a customer/user. OK, back to my hand full of turd balls. These arrays aren't going to index themselves. Richard Tags
May 13 2008, 07:56 PM
Post
#11
![]() I'm a LAVA, not a fighter. V I Engineering, Inc. ![]() Posts: 3637 Joined: 13-October 03 From: Michigan, USA Member No.: 181 Using LabVIEW Since:1993 LV:8.5 ,. ,.
My Blog
Yes ma'am! To me a driver is software entity that translates opeartional requests into hardware interactions that produce required results. Right - I also think that drivers can have wrappers (like translating error codes that a DLL spits out into a meaningful LabVIEW error cluster) which encapsulate the lower-level driver, and can be thought of as part of the driver itself. I think it's all a matter of your frame of reference. -------------------- ![]() Tags
May 13 2008, 09:46 PM
Post
#12
My Gallery
... it's all a matter of your frame of reference. Argh! OK. WHAT is THIS?...
Tags
May 13 2008, 10:25 PM
Post
#13
My Blog
Argh! OK. WHAT is THIS?... I'd say A that is also a B with some C -------------------- ![]() Tags
May 13 2008, 11:14 PM
Post
#14
Very Active Member Posts: 101 Joined: 26-January 07 From: Seattle, WA Member No.: 7603 Using LabVIEW Since:2006 LV:8.20 ,. ,.
To me a driver is a piece of software whose sole purpose is to pass information from an application's business layer to/from a piece of hardware. If the driver contains business logic it is no longer just a driver and becomes an integrated part of the application. Or as I call it... a PITA.
I see a driver performing much the same role as a translator. If I need to conduct business with someone in Japan, I find a translator so we can communicate. If the translator is making business decisions on his own, then when I get another translator to do business in Sweden my system breaks down. I need to train the Swedish translator to make the same decisions as the Japanese translator. I restrict the translator's function to translation. As to the original question, "When is a VI a 'driver,'" I'd say a single vi is almost never a well-written driver. (I suppose there may be some trivial cases where a single vi could serve as a driver.) A good driver is generally a collection of vis. If your hardware has a single vi as a driver it likely needs to be broken up or rewritten. Tags
May 14 2008, 12:45 AM
Post
#15
My Gallery
A good driver is generally a collection of vis. If your hardware has a single vi as a driver it likely needs to be broken up or rewritten. Well, I think that's true to the extent of complexity of the "thing" you're driving. I've used devices that just do one simple thing and the VI can fit on 1/3 of a screen, such as a high-current relay output board with just two relays. So to your point (or against it) I guess that would be an example of one VI being a well written driver. But I assert that it isn't a driver, but is a LabVIEW VI. I'd say A that is also a B with some C Well, since I wrote it, I can assure you it is a C (Turd Ball). Tags
