May 5 2008, 07:02 AM
Post
#1
![]() Confucius say, Man with tight trousers is pressing his luck. Admin ![]() Posts: 2322 Joined: 13-October 02 From: Planet Earth Member No.: 2 Using LabVIEW Since:1994 LV:8.5 ,8.2.1 ,7.1.1
My Blog
My Gallery
why does a 1D array always become a 2D on for loop borders? Why can't we concatenate a 1D array at the border. It seems that tunnel has the potential to do a lot more than it can right now in regards to array manipulation.
Reason for edit: Moved post to a new thread due to hijack, deleted irrelevant text that referred to old thread.
-------------------- Tags
| Ad |
Post
Tags
May 5 2008, 07:58 AM
Post
#2
![]() 1 more post to go! Member Posts: 9 Joined: 12-January 07 From: Randers Member No.: 7489 Using LabVIEW Since:1997 LV:6.1 ,8.20 ,.
I like this idea. Along the same lines (or maybe this is hijacking), why does a 1D array always become a 2D on for loop borders? Why can't we concatenate a 1D array at the border. It seems that tunnel has the potential to do a lot more than it can right now in regards to array manipulation. I can't se the picture of what you are talking about. What is wrong ? regards Bjarne Tags
May 5 2008, 01:46 PM
Post
#3
![]() I'm a LAVA, not a fighter. V I Engineering, Inc. ![]() Posts: 3643 Joined: 13-October 03 From: Michigan, USA Member No.: 181 Using LabVIEW Since:1993 LV:8.5 ,. ,.
My Blog
why does a 1D array always become a 2D on for loop borders? Why can't we concatenate a 1D array at the border. It seems that tunnel has the potential to do a lot more than it can right now in regards to array manipulation. I also can't see a picture about what you're talking about, but I agree. If this is implimented, we need to consider making it obvious at the tunnel that this is happening (of course), and there's not much real estate on of those little nodes - it'll be quite a challenge for the NI design team -------------------- ![]() Tags
May 5 2008, 02:14 PM
Post
#4
Changing the world, one VI at a time. Premium Member ![]() Posts: 1665 Joined: 22-October 02 From: San Francisco, CA Member No.: 17 Using LabVIEW Since:1995 LV:8.2.1 ,8.5 ,7.1.1
My Blog
My Gallery
This is what Michael's talking about:
Notes:
May 6 2008, 09:16 PM
Post
#5
![]() Extremely Active Premium Member ![]() Posts: 515 Joined: 18-October 05 From: Seattle, WA Member No.: 3266 Using LabVIEW Since:2005 LV:8.5 ,8.2.1 ,7.1.1
My Blog
I love it!
A simple right-click:concatenate option on the exit tunnel (like the "build array" primative, which is basically the extra code you're trying to eliminate, right?) would be very nice here. I don't see why this would have to be limited to just 1D outputs though. I can see cases with 2D arrays inside a For loop where I would want to concatenate vs. build a 3D array as well. -------------------- Tags
May 7 2008, 07:28 PM
Post
#6
![]() Extwemely Active Premium Member ![]() Posts: 1594 Joined: 23-January 05 From: Here Member No.: 1431 Using LabVIEW Since:2003 LV:7.0 ,7.1 ,.
I wanted something like this for a long time as well.
This should also work for strings If you're refering to concatenating different strings into a single one, you can sort of do that - build them into an array and then concatenate the array:
-------------------- More than meets the eye...
Tags
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
9 | YouMiss | 5622 | 12th September 2007 - 06:18 PM Last post by: TobyD |
1 | andy810915 | 2460 | 4th September 2003 - 04:30 AM Last post by: Michael_Aivaliotis |
0 | BienEntendu | 2408 | 25th December 2003 - 01:55 PM Last post by: BienEntendu |
4 | aledain | 1818 | 2nd April 2004 - 07:57 AM Last post by: aledain |
| Time is now: 10th October 2008 - 11:37 PM |
