May 1 2008, 03:33 PM
Post
#1
![]() 3 more posts to go! Member Posts: 7 Joined: 1-May 08 From: beijing china Member No.: 11393 Using LabVIEW Since:2008 LV:8.5.1 ,. ,.
My Blog
Soft name: DRS
Soft Ver: 2008 Soft language: Engish Run environment: Win9x/NT/2000/XP Soft size: 1901KB Soft presentation: Least Cubic Method is a new method for data regression analyse , it expanded Least Square Method, According to the principle, this program can be used to work out single factor linear data regression, multi factors linear data regression, single factor non-linear data regression, and multifactors non-linear data regression. Soft download1: http://www.download.com/DRS/3000-2053-10786191.html?part=dl-DRS&subj=uo&tag=button chart of multivariate nonlinear Purchase contact: ww_yypp@163.com Purchase web: http://www.eaihua.com Tags
| Ad |
Post
Tags
Jun 13 2008, 07:56 AM
Post
#2
I've come back for more. Member Posts: 2 Joined: 12-June 08 Member No.: 11748 Using LabVIEW Since:2008 LV:8.5.1 ,. ,.
I have a chart(as follows), want regression analysis to a model (formula), "Least Cubic Method" can do it?
Tags
Jun 25 2008, 09:54 AM
Post
#3
My Blog
Hi sqh
Chart of you sent me at below, processing methods such as the following steps. step 1: Confirm the factor value and goal calculating value (goal function). Step 2: from the chart to Read abundance data. Step 3: Use DRS software to enter data and Finally dimension as the objective function. Step 4: Calculation of regression. Format of enter data(factor value1,factor value2,goal function) 150 200 200 100 3 300 300 45 400 ..... ..... ..... 200 0.7 450 300 0.8 600 300 0.025 700 Tags
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
0 | Markphaser | 1020 | 13th February 2006 - 05:39 AM Last post by: Markphaser |
0 | vronto31 | 875 | 14th July 2006 - 03:23 PM Last post by: vronto31 |
2 | salvai.m | 508 | 18th July 2006 - 10:55 AM Last post by: salvai.m |
33 | Tomi Maila | 9714 | 30th September 2006 - 04:49 PM Last post by: robijn |
| Time is now: 12th October 2008 - 09:00 AM |
