> Related links
Visit our LabVIEW Wiki LabVIEW Embedded Portal
Tags
> Saving changes to FPGA subVI?, saving changes to different instances?
vestman
post Apr 29 2008, 02:09 PM
Post #1
1 more post to go!
Member
Using LabVIEW Since:2007
LV:8.5 ,8.20 ,.
Sweden swe_skane Nothing Selected
hi
I'm building a set of FPGA subVIs for use in our future cRIO applications. The subVIs will be of type "8 channel DO", "8 channel DI", "8 channel PWM" et.c, with an array as input.
I want the user to be able to place a subVI on the block diagram, connect an input, open the front panel of the subVI and select which 8 channels to use (from an I/O name control).
This is not a problem to implement, but what about using multiple instances of the same VI? All subVIs point to the same file and hence changes to one equals changes to all.
Is there a way around this, to be able to save changes made to every subVI placed on the block diagram independently?
/Emil
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Ton
post Apr 29 2008, 04:09 PM
Post #2
CCT It
Premium Member
Using LabVIEW Since:2001
LV:8.5.1 ,6.1 ,8.2.1
Netherlands hol_utrecht Nothing Selected My Blog My Gallery
QUOTE (vestman @ Apr 29 2008, 04:09 PM) *
This screams Express VIs. Norm Kirchner say they aren't that hard to program, so good luck!
Ton
Certified LabVIEW Developer
Shouldn't you be programming a Code Repository solution?
Tags
+Quote Post
vestman
post May 5 2008, 08:07 AM
Post #3
1 more post to go!
Member
LV:8.5 ,8.20 ,.
Thank you. I was afraid that would be the case.
Do you know if there are limitations when creating Express VIs for the FPGA-palette?
Tags
+Quote Post
LV_FPGA_SE
post Jun 26 2008, 03:11 PM
Post #4
NI
Using LabVIEW Since:1993
LV:8.5.1 ,8.2.1 ,8.6
us_texas Canada Germany My Gallery
I'm just catching up on some older messages.
Another possible solution to this problem is to use I/O references (new in LabVIEW FPGA) in the subVI and specify the I/O channel as constants in the calling VI. The subVI does not need to change and the user can specify the specific I/O in a clear readable fashion. You cannot put the I/O references into an array to pass to the subVI, but you can bundle them in a cluster. I have attached a very simple example for 8 DI channels.
Attached File(s)
Attached File  8_Channel_DI__Cluster_.vi ( 488.65K ) Number of downloads: 66
Attached File  Use_8_Channel_DI__Cluster_.vi ( 203.86K ) Number of downloads: 54
Christian L
NI Systems Engineering - Real-Time and Embedded Control Technologies
"I like my G code neat."
Tags
+Quote Post
ExpoEra
post Sep 9 2008, 05:42 PM
Post #5
3 more posts to go!
Member
Using LabVIEW Since:2008
LV:8.6 ,. ,.
Nothing Selected Nothing Selected Nothing Selected
QUOTE (LV_FPGA_SE @ Jun 26 2008, 08:11 AM) *
For the "Use 8 Channels", how do I use it? When I try to compile it, it says channel not found. When I actually assign a channel to it, the wire between the cluster and subVI becomes broken.
Tags
+Quote Post
LV_FPGA_SE
post Sep 9 2008, 06:26 PM
Post #6
NI
QUOTE (ExpoEra @ Sep 9 2008, 12:42 PM) *
You should first create a new project and configure your FPGA target and all of the I/O for your target that you plan to use. Then add the two VIs to the FPGA target. Open up the Use 8 Channels and help it find the subVI if necessary.
Then if you go to the diagram you should be able to click on the I/O references and select any of the channels you have configured in the project for your FPGA target.
Christian L
Tags
+Quote Post
ExpoEra
post Sep 10 2008, 04:28 PM
Post #7
3 more posts to go!
Member
LV:8.6 ,. ,.
QUOTE (LV_FPGA_SE @ Sep 9 2008, 11:26 AM) *
Yea, I did all of those. The strange part is that when I click on the I/O references, it says "No I/O Available". I am very sure I have configured the I/O for my target correctly. sad.gif
Tags
+Quote Post
LV_FPGA_SE
post Sep 10 2008, 08:13 PM
Post #8
NI
QUOTE (ExpoEra @ Sep 10 2008, 11:28 AM) *
What I/O modules and channels have you configured? Can you attach a screen shot of the project with the configuration or the project file.
Make sure the VIs are assigned to the same FPGA target in the project.
This post has been edited by LV_FPGA_SE: Sep 10 2008, 08:13 PM
Christian L
Tags
+Quote Post
ExpoEra
post Sep 10 2008, 08:22 PM
Post #9
3 more posts to go!
Member
LV:8.6 ,. ,.
QUOTE (LV_FPGA_SE @ Sep 10 2008, 01:13 PM) *
The folders saying Connector 0, 1, etc have the I/Os in them.
Tags
+Quote Post
LV_FPGA_SE
post Sep 11 2008, 03:44 AM
Post #10
NI
QUOTE (ExpoEra @ Sep 10 2008, 03:22 PM) *
It turns out the IO references are somewhat specific to the type of IO device. My original VI was created for cRIO IO. I updated the example for R series and have attached the new VIs and project.
Attached File(s)
Christian L
Tags
+Quote Post
ExpoEra
post Sep 11 2008, 05:00 PM
Post #11
3 more posts to go!
Member
LV:8.6 ,. ,.
QUOTE (LV_FPGA_SE @ Sep 10 2008, 08:44 PM) *
Tags
+Quote Post
Time is now: 4th December 2008 - 06:09 AM
