Tags
> Crashes with Merge VI, Merge VI from PC crashes Mac or Linux
SULLutions
post Jan 13 2005, 02:12 PM
Post #1
Active
Member
Using LabVIEW Since:1993
LV:7.1.1 ,7.0 ,8.5
United States Nothing Selected Nothing Selected
A merge VI from the LabHSM package created with LabVIEW 7.0 on a PC reproducibly crashes Mac or Linux systems running 7.1 or 7.1.1 during the merge process. (It works fine under all versions on PCs and under 7.0 on Macs.)
By whittling the VI down, I found that the culprit was an error case structure. Removing and replacing the case structure, whether on a Mac or a PC, cured the problem. Apparently, the exact sequence in forming the case structure introduced a subtle error.
NI is investigating, but has no result so far.
If you see this problem, suspect case structures.
EnWirementally,
Paul F. Sullivan
www.SULLutions.com
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Time is now: 21st November 2008 - 02:13 PM
