Tags
> Crashes with Merge VI, Merge VI from PC crashes Mac or Linux
SULLutions
post Jan 13 2005, 02:07 PM
Post #1
Active
Member
Using LabVIEW Since:1993
LV:7.1.1 ,7.0 ,8.5
United States Nothing Selected Nothing Selected
A merge VI from the LabHSM package created with LabVIEW 7.0 on a PC reproducibly crashes Mac or Linux systems running 7.1 or 7.1.1 during the merge process. (It works fine under all versions on PCs and under 7.0 on Macs.)
By whittling the VI down, I found that the culprit was an error case structure. Removing and replacing the case structure, whether on a Mac or a PC, cured the problem. Apparently, the exact sequence in forming the case structure introduced a subtle error.
NI is investigating, but has no result so far.
If you see this problem, suspect case structures.
EnWirementally,
Paul F. Sullivan
www.SULLutions.com
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Collapse
> Similar Topics
    Topic Title Replies Topic Starter Views Last Action
No New Posts   0 TomWP 2359 10th February 2004 - 04:25 PM
Last post by: TomWP
No New Posts   3 rpursley 1494 14th November 2006 - 01:40 PM
Last post by: jimi
No New Posts   7 jools 1913 8th December 2004 - 09:20 AM
Last post by: didierj
No New Posts   0 SULLutions 1378 13th January 2005 - 02:12 PM
Last post by: SULLutions
Time is now: 8th September 2008 - 10:54 AM
