Visit our LabVIEW Wiki External Code Portal.
Mar 26 2008, 02:41 PM
Post
#1
I've come back for more. Member Posts: 2 Joined: 26-March 08 Member No.: 11150 Using LabVIEW Since:2008 LV:8.5 ,. ,.
Hello! Searched through the forums and nothing found for this topic.
--------------------------------- I have a program that reads data from PCI board memory. Stuck with using CIN's and decided accomplish this task with Call Library Function Node. --------------------------------- I use linux Ubuntu kernel 2.6 and program C code, LabView 7.1 i specify -lpci library for compiling my code. and use header file included. --------------------------------- 1) How to pass to Call library function node - parameter which is defined in "pci.h" as a structure with pointers? 2) Do I need to write wrapper for it ? If so is there well manuals? 3) Can I compile my entire program (which uses functions defined in pci.h and in library libpci.so) as a shared library .so and call functions directly from my library? or I should call those functions only from libpci.so separetely? P.S: I use mmap( .... ) function for returning pointer to memory with data on device. Thanks in advance. Tags
| Ad |
Post
Tags
Apr 3 2008, 06:54 PM
Post
#2
mde...
Tags
Apr 4 2008, 07:34 PM
Post
#3
![]() Extremely Active Premium Member ![]() Posts: 381 Joined: 19-June 07 From: Everett, WA Member No.: 8758 Using LabVIEW Since:2007 LV:8.6 ,8.5.1 ,8.2.1
mde... I've been wondering what "mde" means for a full day now. All I could come up with after googling it was Mucinous Ductal Ectasia. I can't make that make sense in the context of the post...any ideas? Tags
Apr 4 2008, 08:48 PM
Post
#4
![]() Extremely Active Premium Member ![]() Posts: 515 Joined: 18-October 05 From: Seattle, WA Member No.: 3266 Using LabVIEW Since:2005 LV:8.5 ,8.2.1 ,7.1.1
My Blog
I've been wondering what "mde" means for a full day now. All I could come up with after googling it was Mucinous Ductal Ectasia. I can't make that make sense in the context of the post...any ideas? My suspicion was it was some equivelant to "bump", since there wasn't a response yet. Either that or More Draft -- Edelweiss! -------------------- Tags
Apr 7 2008, 07:32 AM
Post
#5
Extremely Active Premium Member ![]() Posts: 978 Joined: 9-April 04 From: Rotterdam Member No.: 349 Using LabVIEW Since:1992 LV:8.5.1 ,8.2.1 ,7.1.1
My suspicion was it was some equivelant to "bump", since there wasn't a response yet. Either that or More Draft -- Edelweiss! Don't know that brand but yes come on with it Rolf Kalbermatter Tags
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
4 | JPrevost | 2346 | 10th January 2006 - 07:49 PM Last post by: JPrevost |
1 | seckley | 5501 | 20th December 2002 - 04:36 AM Last post by: Michael_Aivaliotis |
4 | Paul | 1798 | 12th June 2004 - 08:34 PM Last post by: Khalid Ansari |
3 | Deep_Blue | 1761 | 28th May 2004 - 12:39 PM Last post by: rolfk |
| Time is now: 16th October 2008 - 08:13 PM |
