> Related links
Visit our LabVIEW Wiki Code Distribution Portal
Tags
> Build on XP 32, install on Vista 64?
AutoMeasure
post Mar 25 2008, 08:34 PM
Post #1
Premium Member
Using LabVIEW Since:1991
LV:8.5.1 ,8.2.1 ,7.1
United States us_massachusetts Nothing Selected
If I build a Labview application and installer with Labview 8.5 running on Windows XP 32-bit OS, and the installer includes the Run-Time Engine, will it install and run correctly on a Windows Vista 64-bit machine? Thanks.
Joe Czapski - Senior Project Engineer - Bloomy Controls, Inc.
Services include:
> custom automated test and control systems
> complete turnkey systems with rugged custom fixturing
> LabVIEW programming
> project management
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
TobyD
post Mar 26 2008, 03:58 PM
Post #2
Premium Member
Using LabVIEW Since:2007
LV:8.6 ,8.5.1 ,8.2.1
United States Italy Nothing Selected
QUOTE (AutoMeasure @ Mar 25 2008, 01:34 PM) *
Your program could work on a 64-bit machine, but there are a lot of things to consider. Take a look at this article. Basically, Microsoft implements a 32-bit emulation layer that enables 32-bit programs to run as though on a 32-bit version of Windows by translating instructions passing in and out of the applications into 64-bit instructions. These programs will not take advantage of the added memory addressing capabilities of a 64-bit OS.
Other things that could cause problems are your hardware drivers and any call to system dlls. System32.dll or User32.dll are now Sytem64 and User64. I assume the emulation layer handles this and these calls will still work, but I don't have enough experience with it to say for sure.
Toby
Tags
+Quote Post
Travis Pape
post May 23 2008, 03:12 PM
Post #3
I've come back for more.
Member
Using LabVIEW Since:1990
LV:8.5.1 ,. ,.
United States us_north_carolina Nothing Selected
QUOTE (AutoMeasure @ Mar 25 2008, 03:34 PM) *
I have the same question. The only NI driver my application installs is NI-VISA runtime for accessing a USB UART bridge and I am building on XP 32-bit.
Would my app install and run on Vista 64-bit?
Would it run better on Vista 64-bit if I built it using a Vista 64-bit machine?
Thanks
Tags
+Quote Post
Jeff B
post May 23 2008, 06:34 PM
Post #4
Active
NI
Using LabVIEW Since:1999
LV:8.5 ,8.2.1 ,8.0.1
Nothing Selected Nothing Selected Nothing Selected
Just thought I'd add a couple of comments... Some of it is new info, some is just a different way of saying what TobyD said...
An application built with LabVIEW 8.5 will be a 32-bit executable. It will run in the 8.5 run-time engine (also 32-bit) regardless of the bitness of Windows (runs in the WoW layer on Vista x64). The same installer should get built regardless of whether the machine building it is running 32-bit or 64-bit Vista, and it will install on either one as well.
Saying that a 32-bit application will not be able to take advantage of the larger amounts of memory available to a 64-bit OS is not entirely true. On a 32-bit OS, LabVIEW 8.5 can access only up to 3 GB RAM, and even then, only if you have the /3GB boot option. On Vista x64, LabVIEW 8.5 (and therefore a LabVIEW 8.5-built executable) can access up to a full 4 GB RAM. However, as it is still a 32-bit application, it cannot go beyond this, which I believe was TobyD's point.
Also, contrary to what TobyD mentioned, USER32.DLL and KERNEL32.DLL have not changed name. Both the 32-bit and 64-bit versions of these DLLs exist on Vista64, but they are BOTH still named USER32.DLL and KERNEL32.DLL. Further, as counter-intuitive as it might seem, the 64-bit versions of these live C:\WINDOWS\System32, and the 32-bit versions live in C:\WINDOWS\SysWOW64. No, I didn't mix those up, maybe Microsoft did, but the product's released now, so oh well. wink.gif At any rate, you shouldn't have to worry about this too much, as 32-bit applications know to look for these things in the 32-bit location, and 64-bit applications know to look for them in the 64-bit location. That's not to say that any application written on 32-bit Vista or XP will work on 64-bit Vista. The article TobyD referenced is good to make sure your application is both Vista and 64-bit ready. But as far as the NI components, you should be fine.
Finally, I had to look up the details on VISA support. It looks like VISA 4.1 was the first version to support 64-bit OSs. As long as you have VISA 4.1 or later installed on the machine where you're building the installer, it shouldn't matter whether the machine is running a 32-bit or 64-bit OS.
Hope this helps!
Jeff
This post has been edited by Jeff B: May 23 2008, 06:36 PM
Tags
+Quote Post
Travis Pape
post May 23 2008, 07:21 PM
Post #5
Member
LV:8.5.1 ,. ,.
Thanks Jeff,
I have a user on Vista 64-bit who is reporting that the installer for my app gives a "No software will be installed or removed" message, but I suspect that it might be because they have already installed it and don't realize it. (Yes, I've supported customers who have had that problem.)
Travis
Tags
+Quote Post
TobyD
post May 23 2008, 07:52 PM
Post #6
Premium Member
QUOTE (Jeff B @ May 23 2008, 11:34 AM) *
Thanks for the added info Jeff! I'm sure this article will get a lot more hits as more and more people start making the switch to 64bit. Good Stuff thumbup1.gif
Tags
+Quote Post
Time is now: 4th December 2008 - 05:55 AM
