Mar 20 2008, 02:51 PM
Post
#1
I want a LabVIEW icon under my name! Member Posts: 3 Joined: 20-June 07 Member No.: 8766 Using LabVIEW Since:2000 LV:8.20 ,7.1 ,6.0
It would be usefull to group multiple property nodes and have the possibility to configure all of them with the same parameters by only one action.
Same idea for creating references to multiples objects. It is really boring to have to pick up all of them one by one and cascade right clicks. Tags
| Ad |
Post
Tags
Mar 20 2008, 04:12 PM
Post
#2
Very Active Member Posts: 239 Joined: 30-December 05 Member No.: 3786 Using LabVIEW Since:1998 LV:8.5 ,8.20 ,7.1
I'm not sure what you want. Could you be more specific? If you are expecting to invoke methods or change properties throughout your code call all of the references at the beginning of your code, bundle them into a cluster and pass the data through iterations of your code with a shift register. If you want to perform the same operation on numerous references, many properties (visible, disabled) can be changed as a more generic class. Simply unbundle the references from the cluster, build an array with them and perform the same operation on them with a property node inside a For Loop.
-------------------- "Whether they be the musician cats in my band or the real cats of the world, they all got style." -Ray Charles
Tags
Mar 20 2008, 04:37 PM
Post
#3
Extremely Active Premium Member ![]() Posts: 426 Joined: 2-February 05 From: Southern California Member No.: 1519 Using LabVIEW Since:2004 LV:8.20 ,7.1.1 ,8.0.1
It would be usefull to group multiple property nodes and have the possibility to configure all of them with the same parameters by only one action. Same idea for creating references to multiples objects. It is really boring to have to pick up all of them one by one and cascade right clicks. I believe you are asking for more 'Group Editing' options. There is a little bit of this, but it is limited to font changes and alignment/distribution. It would be REALLY nice to be able to select a group of objects and have the right-click menu give me a list of changes and actions that are common to the group. Tags
Mar 21 2008, 10:20 AM
Post
#4
I believe you are asking for more 'Group Editing' options. There is a little bit of this, but it is limited to font changes and alignment/distribution. It would be REALLY nice to be able to select a group of objects and have the right-click menu give me a list of changes and actions that are common to the group. It IS exactly the point. I can't believe i am the only one to think it is some of most tedious things to do with LV. Tags
Mar 21 2008, 11:04 AM
Post
#5
![]() LV R&D Envoy NI ![]() Posts: 1144 Joined: 15-August 06 From: Austin, TX Member No.: 5877 Using LabVIEW Since:2000 LV:8.5.1 ,. ,.
My Gallery
It IS exactly the point. I can't believe i am the only one to think it is some of most tedious things to do with LV. Oh, I'm pretty sure you're not the only one. In fact, not that I've seen the customer feedback data or anything, but I wouldn't be surprised if NI were working on something exactly like this for an upcomming release. :-) -------------------- "A VI outside a class is a gun without a safety. Data outside a class is a target."
--- A message from LabVOOP R&D Tags
Mar 21 2008, 11:12 AM
Post
#6
Extremely Active Premium Member ![]() Posts: 955 Joined: 9-April 04 From: Rotterdam Member No.: 349 Using LabVIEW Since:1992 LV:8.5.1 ,8.2.1 ,7.1.1
It IS exactly the point. I can't believe i am the only one to think it is some of most tedious things to do with LV. I can't say more than that you should maybe apply for the LabVIEW Beta program at www.ni.com/beta Rolf Kalbermatter Tags
Mar 21 2008, 03:52 PM
Post
#7
![]() Extremely Active Premium Member ![]() Posts: 509 Joined: 18-October 05 From: Seattle, WA Member No.: 3266 Using LabVIEW Since:2005 LV:8.5 ,8.2.1 ,7.1.1
My Blog
It IS exactly the point. I can't believe i am the only one to think it is some of most tedious things to do with LV. Nope, not the only one. This has been discussed a fair amount already in the forums. Oh, and yes... I'm excited that there is a "rustling in the wind" that may indicate we could see something like this coming soon. -------------------- Tags
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
4 | JPrevost | 2154 | 10th January 2006 - 07:49 PM Last post by: JPrevost |
1 | PJM_labview | 2633 | 19th October 2005 - 02:33 PM Last post by: PJM_labview |
4 | Jim Kring | 2099 | 28th October 2003 - 04:06 PM Last post by: Jim Kring |
2 | Michael_Aivaliotis | 1642 | 21st February 2004 - 09:58 PM Last post by: Michael_Aivaliotis |
| Time is now: 30th August 2008 - 02:25 AM |
