Tags
> Resizing images
Yair
post Mar 1 2008, 07:50 PM
Post #1
Extwemely Active
Premium Member
Using LabVIEW Since:2003
LV:8.6 ,7.0 ,.
Israel Nothing Selected Nothing Selected
Michael, I know there was probably a thread about this already (I even seem to vaguely remember it), but I couldn't find it.
Do images embedded in posts always have to be resized? At home, I usually have an 800x600 display, which is probably the minimum anyone would have, and even images which are not very wide and would fit nicely in that screen get resized, so that I have to open them in a new window.
Is it possible to set a minimum width for images being resized (e.g. the image will only be resized if it is wider than 500 pixels)?
More than meets the eye...
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Michael_Aivaliot...
post Mar 2 2008, 01:03 AM
Post #2
Group Icon
Admin
Using LabVIEW Since:1994
LV:8.5 ,8.2.1 ,7.1.1
I've increased the width from 400px to 500px and the height from 300px to 400px.
Tags
+Quote Post
Yair
post Mar 2 2008, 05:44 PM
Post #3
Extwemely Active
Premium Member
LV:8.6 ,7.0 ,.
I didn't realize this was already an option.
Looking at the way the site is rendered here, the text area is about 580 pixels wide, so I would say you can bump it to 550 without risking anything and the benefits are worth it.
The viewable height in my browser is around 430 pixels, so I would say 400 is fine for the height, although I think height is less important than width, since we already scroll up and down.
Thanks.
Edit - even better, would it be possible to make this a user setting?
Tags
+Quote Post
Yair
post Mar 13 2008, 07:56 PM
Post #4
Extwemely Active
Premium Member
LV:8.6 ,7.0 ,.
This still doesn't seem to work correctly:
Edit: this came from here and I'm using IE 7.
Tags
+Quote Post
TobyD
post Mar 13 2008, 08:35 PM
Post #5
Premium Member
Using LabVIEW Since:2007
LV:8.6 ,8.5.1 ,8.2.1
United States Italy Nothing Selected
QUOTE (Yen @ Mar 13 2008, 11:56 AM) *
I am also running IE7 and neither of these images (the image above or the image from the original post) were resized on my machine (1920x1200).
This post has been edited by TobyD: Mar 13 2008, 08:37 PM
Tags
+Quote Post
Yair
post Mar 13 2008, 09:30 PM
Post #6
Extwemely Active
Premium Member
LV:8.6 ,7.0 ,.
Yes, when I change my resolution from 800x600 to 1024x768 it changes the compression level, but it actually went the wrong way - it compressed it more.
Interestingly, it seems to compress it by the ratio of the image and the screen width (1-(383/800)=~0.52, 1-(383/1024)=~0.66). I guess that when it goes over a certain limit, it stops doing this.
Tags
+Quote Post
Yair
post Mar 15 2008, 07:39 PM
Post #7
Extwemely Active
Premium Member
LV:8.6 ,7.0 ,.
Another interesting point is that the image is actually displayed in its proper size until the page finishes loading and only then is minimized.
Tags
+Quote Post
Michael_Aivaliot...
post Mar 15 2008, 09:11 PM
Post #8
Group Icon
Admin
Ya, I don't notice the resize. I'm running 1920x1200 (isn't everyone?) and I didn't even know it was taking your native resolution into consideration. I'll look into it some more.
Update: Ok, Yen I think I finally figured this one out. The images should be fine now even on low resolution systems. Check it now.
Tags
+Quote Post
Yair
post Mar 16 2008, 07:17 PM
Post #9
Extwemely Active
Premium Member
LV:8.6 ,7.0 ,.
It seems to work fine now, thanks.
QUOTE (Michael_Aivaliotis @ Mar 15 2008, 11:11 PM) *
Well, at home I usually use a PC with an old 17" CRT and I sit a bit far from the screen, so 800x600 seems to be a reasonable resolution. Since I don't really do LabVIEW work on this computer, I don't really mind.
Tags
+Quote Post
Time is now: 21st November 2008 - 12:02 PM
