Tags
> Ability to run selected section of block diagram
PatNN
post Feb 1 2008, 02:28 AM
Post #1
I've come back for more.
Member
Using LabVIEW Since:2001
LV:8.5 ,. ,.
Cameroon United States Nothing Selected
Ability to run selected section of the block diagram without having to run the entire VI. This would be a useful debugging feature.
Right now I have to select the portion I'm interested in, and create a new VI out of it (or a subVI, with the drawback that I can't easily undo the changes to the original VI)
Would be nice to just be able to select a section of the block diagram of interest, interactively initialize the inputs or optionally use the default values, and run it.
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Ton
post Feb 1 2008, 08:03 AM
Post #2
CCT It
Premium Member
LV:8.5.1 ,6.1 ,8.2.1
Netherlands hol_utrecht Nothing Selected My Blog My Gallery
QUOTE (PatNN @ Feb 1 2008, 03:28 AM) *
Well that is why you put stuff in one VI, to do unit tests and stuff.
Ton
Certified LabVIEW Developer
Shouldn't you be programming a Code Repository solution?
Tags
+Quote Post
Phillip Brooks
post Feb 1 2008, 11:39 AM
Post #3
Premium Member
Using LabVIEW Since:1999
LV:7.0 ,8.20 ,8.0
us_massachusetts France Thailand My Gallery
QUOTE (PatNN @ Jan 31 2008, 09:28 PM) *
You can create a sub-vi from a section of a block diagram. The input and output connectors will be created for you.
Tags
+Quote Post
jzoller
post Feb 1 2008, 03:45 PM
Post #4
Member
Using LabVIEW Since:2002
LV:8.2.1 ,7.1 ,6.0.2
United States us_colorado Nothing Selected
I have to agree with PatNN on this one. That would be a feature I would use.
On a more general note, workarounds != native support, and should never be used as an excuse for not providing native support for good features.
Joe Z.
Tags
+Quote Post
JoeLabview
post Feb 1 2008, 11:07 PM
Post #5
Member
Using LabVIEW Since:1993
LV:8.20 ,7.1 ,6.1
Canada Canada Canada
QUOTE (tcplomp @ Feb 1 2008, 03:03 AM) *
Ton
Yes, in 90% of the cases, I agree.
Strangely enough, I just posted a similar feature request at another forum wink.gif
There are cases where you have to test your vi as embedded into the final code, but don't want to run the entire thing to get to where you want to be...
Now, you have to remember, this is the "Wish List" section... I'm sure this feature would be a sunnovogun to implement... But hey, we gatta keep them NI folks busy!..
Good suggestion!
Tags
+Quote Post
Daklu
post Feb 19 2008, 07:33 PM
Post #6
Member
Using LabVIEW Since:2006
LV:8.20 ,. ,.
United States us_washington Nothing Selected
QUOTE (PatNN @ Jan 31 2008, 06:28 PM) *
I'd be thrilled if I could simply ignore sections of code while I'm debugging. For instance, if I'm stepping through code that contains parallel loops I'm constantly being shifted around the block diagram to view the next code step when I'm only interested in the code in *this* loop. It gets frustrating.
Tags
+Quote Post
crelf
post Feb 19 2008, 08:11 PM
Post #7
I'm a LAVA, not a fighter.
V I Engineering, Inc.
LV:8.5 ,. ,.
Australia United States Nothing Selected My Blog
QUOTE (Daklu @ Feb 19 2008, 02:33 PM) *
...if I'm stepping through code that contains parallel loops I'm constantly being shifted around the block diagram to view the next code step when I'm only interested in the code in *this* loop.
So you want a diagram disable structure that disables the code outside the structure, instead of inside it? That's a freakin' awsome idea! thumbup1.gif
Tags
+Quote Post
Daklu
post Feb 20 2008, 05:18 AM
Post #8
Member
LV:8.20 ,. ,.
QUOTE (crelf @ Feb 19 2008, 12:11 PM) *
Wish I could lay claim to it, but that's actually the op's idea. It's a little difficult to explain what I'm asking for. I want to be able to select or otherwise indicate the code segment I am interested in. All the code is executed but only the selected code is "debugged." Any non-selected code that executes while I'm stepping through my selected code isn't highlighted, doesn't display values, doesn't change my view to that to that location, etc.
I created a vi that illustrates the problem I'm hoping this would address. Open the block diagram, click Highlight Execution, and step through the math loop.
Attached File(s)
Tags
+Quote Post
crelf
post Feb 20 2008, 04:03 PM
Post #9
LV:8.5 ,. ,.
QUOTE (Daklu @ Feb 20 2008, 12:18 AM) *
Tags
+Quote Post
robijn
post Feb 20 2008, 04:34 PM
Post #10
Member
Using LabVIEW Since:2008
LV:7.1.1 ,8.5.1 ,8.2.1
Netherlands Nothing Selected Nothing Selected
I wanna change values in wires while debugging !
Joris
Tags
+Quote Post
crelf
post Feb 20 2008, 05:17 PM
Post #11
LV:8.5 ,. ,.
QUOTE (robijn @ Feb 20 2008, 11:34 AM) *
I wanna gold-plated toilet seat!
Tags
+Quote Post
dbyers3
post Feb 20 2008, 05:31 PM
Post #12
Active
Member
LV:8.2.1 ,. ,.
Nothing Selected Nothing Selected Nothing Selected
QUOTE (crelf @ Feb 20 2008, 11:17 AM) *
Tags
+Quote Post
Collapse
> Similar Topics
    Topic Title Replies Topic Starter Views Last Action
No New Posts   12 JasonD 1943 1st October 2008 - 10:52 PM
Last post by: Minh Pham
No New Posts   3 DMiller 2463 9th July 2004 - 04:48 AM
Last post by: Jim Kring
No New Posts   2 Michael_Aivaliotis 1757 21st February 2004 - 09:58 PM
Last post by: Michael_Aivaliotis
No new   17 Michael_Aivaliotis 3435 1st April 2008 - 01:12 PM
Last post by: mseb
Time is now: 6th October 2008 - 11:23 PM
